yamahayz250 Tail pipe leaking like crazy
i need help with my 03 yz250. whenever i go riding the bike leaks a lot of oil out the fmf tail pipe(like a lot) im tired of having to scrub all the oil off my swingarm and brake, i just re did the packing and its still leaking? the bike runs perfectly fine and its jetted for my elevation in Reno. any tips?
What is your current jetting?
Have you set your float height lately? How old are your reed petals and top end? Do you adjust your airscrew with the weather, or did you just set it and forget it? Which FMF silencer does your bike have (Some spooge easily).
Spooge is most frequently caused (jetting wise) by the airscrew/pilot and the needle clip position. Worn engine parts like reeds and piston rings will make an engine close to un-jettable. Another possibility is expired crank seals.
http://www.thumpertalk.com/topic/347305-is-your-two-stroke-running-rich-read-here/
http://users.conwaycorp.net/virtus/page2/speed/jetting.htm
http://users.conwaycorp.net/virtus/page2/speed/jetting%20flowchart.htm
:rolleyes: how could a 14 year old bike need any of that?
  • Like 2
i just got new v vorce 3 reeds and just replaced the top end. i have my bike jetted for 5,000 feet above sea level because i live in northern nevada and i have the q stealth silencer with new packing.
Did you seal the silencer with silicone when you reassembled it?
Unless you're riding wide open constantly there will be spooge. It's a fact of life with a 2 stroke. WD will take it off if you don't let it build up. Brake or contact cleaner seem to work the best.
thats what i do after every ride just sick of it lol
