FMF Q stealth on YZ250X
Is there a reason that FMF don't list the Q stealth for use on the 'X'? Any one got one on a 250X, if so how do you find it? Does it work? Am thinking of fitting it with the Gnarly front pipe too, does this combo work, or am I wasting my moolah?
Yes, this combo works. One isn't listed for the X because hardware connections are the same as the non X. If you need a spark arrestor to ride in U.K. then I'd consider one. Otherwise the stock exhaust is very good and no need to replace it unless it banged up or broken IMO. The X front pipe is supposed to be more tucked in than the non X pipe so there is that going for it too.
Q Stealth might be 1-3 dB quieter than stock. Q Stealth known to make spooge.
