kx250f part questions
You can probably call the shop you're looking to buy it from and confirm. That said, you can also look at the fiche and compare part numbers between years. If the part numbers are the same, it should be a one to one fit. If they're different, you can do some more research and check compatibility.
Edited by RageD
