2005 RM250 will this Moose DC8 clutch perch work?
Hi I'm thinking of upgrading from my oem clutch perch to one of these since you can find them pretty cheap Moose DC8 clutch perch and I would like to have a better slop free feel since I am constantly using the clutch. I heard that Suzuki's need a special pull ratio lever so I thought I'd ask around. Has anyone used this clutch on their RM?
Thanks in advance!
I have not used the perch you posted, but I do use the Works Connection perch.  The modified angle of the clutch lever give it and smooth feel and light pull.  All the aftermarket perches are designed to do the same thing, such as the Works Connection perch, so the one you posted should give you the same results. It is a good part to upgrade to.  I suggest that you buy some back up levers for the perch you select unless it states to use the stock lever.  My Works perch uses a longer clutch lever.
