Can I put an E header only on S bike?
The front head pipe will fit but it is too big to fit into the muffler unless the muffler inlet is expanded to allow it to fit.The e pipe is only slightly less restrictive than a s model.You'll have much better gains with a well designed aftermarket full system.
  • Like 2
^ What he said. You probably won't see gains with just a header, the stock midpipe is a smaller diameter and the muffler is restrictive.
Above all a full system is your best bet for sure.  If you were to take some baffles out of the S muffler in combo with the E header you might but you are better off using a good slip on if you are intent on the E header as well.
