1988 cr250 brake caliper mount removal.
Hello fellow TT's... In need of any info if a brake caliper can be removed from its caliper bracket. I'm currently installing conventional forks back on my 88' as previous owner had incorrect inverted forks from an 89'. This evening I have installed forks triple clamps but couldn't remove the bracket off the 88' brake caliper. The one that is currently on the bike is a 89'. Calipers look identical but the brackets are different due to the different style forks. Any info is much appreciated. I just wanted to save a step of rebuilding and bleeding the 88' caliper if I could of easily switched the two brackets as the current caliper/master cylinder on bike is working fine.
