YZ 250 5th gear/ Pinion stuck. Transmisson Issue rebuild.
Hello, had a problem with My 250 02. I could shift but not find neutral or specific gear. I Tore the bike apart and everything seemed OK. So i started split the transmission shaft and i think i have located the issuse. The 5th gear do not rotate? Shouldnt IT rotate and i cant get IT of the shaft.. It's number 3 on the pic that i referring to! I also noticed nr 4 was missing, could it be that that cause the issue?
Do anyone know? And can someone confirm this for me?
Edited by Skeppskatten
Add one picture.
1 minute ago, Matthias V. said:
it should rotate, you could try heat to get it loose or press it of with a hydraulic press
Yeah. I got IT off. IT had siezed onto the shaft. So i ordered a new shaft and 5 th gear, new shim!
Make sure you get new clips for the shaft also. I wouldn't trust reusing them.
