Frankenstein's Monster XL/XR finish
Tank , Fork Tubes and hubs XR400
Lower Fork Protectors , Front Break (compleate) , Tripple Clamp , CRF250L
Frame modified, Engine modified , Seat modified ,Front mask and side panels , Stop Switch,Ignition Lock, 83 XL600R
Rims and Spokes Excel
Rear Break , Rear Pegs ,Yamaha Speed MX
Rear Break Disk , XR250 , Front unknown.
Front Pegs , Kawa aftermarket
Swing Arm XR600 87
Rear Shock WP
Front Fender Acerbis
Rear Fender XR600R i guess
Ricky Stator ,all DC , all LED, Lithium 14AH Batterie selfmade wirering loom.
EBC Carbon Clutch Plates with stronger springs , Hydraulic Clutch , Racing Boy modified
Ignitech DCCDIP programmable CDI
DRC Muffler for Yamaha Raptor 700
Power header modified
Kick stand , XR250
Handlebar Pro Taper , Switch CBR600, Dash KOSO DB03 with MSX 125 Oil Temp. sensor in Head
Carbs 2 x Mikuni TM 34 modified
Oil Cooler , Suzuki, Oil Pressure switch , RS Industry supplys
Cam shaft , Rockers , Webcam
Piston , Mahle Germany 104 mm for XR650L/FMX
all selfmade inc. many Parts
Edited by Schrauberklaus
  • Like 2
Swing Arm XR600 87
Rear Shock WP
Kick stand , XR250
More pics of tank and shrouds please. It looks great!
Awesome! :thumbsup: Now we need performance report. :ride:
Fork tubes XR400? USD? :thinking:
O.K. try to answer at once.
Tank 9,5 Liter steel tank is Stock on XR250 from 2004-06 or XR400 2005-08 sold in Japan . Honda use the same Tank on both . Still available new ,Part number 17500-MFB-000ZA , but not cheap .
Pics , from my XR 280 and XR440
And as you can see in this Pics the XR's from 2004-08 comes Stock with USD Fork and elektric start but never make it to USA
Performance ?
Big question , here is no Dyno available .
All i can tell you is that i rode the XL for a few years with the same Engine as Travel Enduro . see Pic .
And in that Trim with over 50 kg more (full Tank , emty Luggage )  a new 2 cyl. Fuel inj. 48 HP CB500F as example had no chance in 0-140 km/h runs.
Top Speed was about 170 km/h
How it perfoms now , lighter then Stock and 1 tooth more on the rear , just great .
Topspeed now with my 100 kg Frame full in the Wind no Idea . But depend the next Road where i could test that is more then 100 km away and the XL is now the short distance
Hooligan Bike , it does not matter.
  • Like 3
1 hour ago, Drhardway said:
Hydraulic clutch...Nice
Just a 55 USD Part from a local Company that work only after extensive modifications .
But takes now the stress out of the Hand from the monster Clutch i need in this Engine .
Hi Klaus
i have seen your pumper Carb replacement build (the TM 34 i think) do you have maybe a link to your other mods i need that tank and seat in my life :)
Regards
Oupoot
where is the side outlet on the comp tee on the oil tube to the head going to?
