2010 No Spark
So I rebuilt my bike two weeks ago and didn't get to start it until last weekend. It fired right up and ran it through the break-in process and all was well. I put it up and went back to college and got home this weekend and decided I was going to ride. I pulled it out of the garage and tried to fire it up but it wouldn't fire. I've been through the stator and coil with a multimeter and disconnected the kill switch to eliminate that and still no spark. Also replaced the spark plug to see if that could be the problem. Any suggestions? Should I just go ahead and buy a cdi off ebay or somewhere?
Recheck all your connections. There have been times when the ground lead wire from the coil was missed (not put under the bolt and grounded to the frame). Also times when connector plugs were not snapped and have come loose.
So I went through everything again with the multimeter and I also ordered a wiring harness with a cdi and coil to double check everything and still no spark. Is a resistance check of the stator sufficient? It is well within spec on the resistance readings, I just don't have a DVA/PVA to check the voltage coming from it. I also checked all the wires on the stator to make sure that that they were not grounded out.
