1992 kx125 oil plug stripped
Title says it all. My 92 kx125 lost the oil plug while i was riding. I probably was riding about 5 minutes after it fell out and it started making an awful whistling/metallic sound. Pretty sure it was the clutch because once i filled it with oil and temporarily plugged the drain the noise went away. Anyway my question is can i drill that drain plug hole out and tap a bigger size? Its totally stripped. I looked inside the hole and it appears there might be an oil valley of some sort in my way. Not sure it this will be kosher so im asking you guys first.
