Bedunjgi
X-Trainer Capacitor/Diode Failure
23 posts in this topic
I am cutting off the factory shrink tube & crimps & re-crimping with heat shrink connectors with adhesive & then covering with heat shrink tubing for additional protection, also in case I pierced the insulation on the crimp & in case I wasn't careful enough putting the dielectric grease covered wires in the crimps since the adhesive doesn't stick on silicone covered wires. They aren't designed to be used with grease but I wanted to. I have been trying to be very careful with the grease & wiping with alcohol before heating & keeping the wires from touching the sides as I put the crimp on. Then I am rewrapping it with split loom & zip ties following my rough tracing & photos before disassembly. For the non-waterproof connections I will either fill with grease & shrink tube the ends to keep it from washing out or when I am connecting the plugs, I will heat shrink them with non adhesive (So it can be cut off) tubing over the entire connection to hold it together & keep the grease from washing out. Products;
Assorted Hook Self Closing Braided Wrap Sleeving; https://www.amazon.com/gp/product/B00QSH06IU/ref=od_aui_detailpages00?ie=UTF8&psc=1
Heat Shrink Wire Connector; https://www.amazon.com/gp/product/B01GXQMP66/ref=od_aui_detailpages00?ie=UTF8&psc=1
3:1 Shrink Ratio Tubing; https://www.amazon.com/gp/product/B01N07O1GO/ref=od_aui_detailpages00?ie=UTF8&psc=1
Dielectric Grease; http://www.homedepot.com/p/CRC-3-3-oz-Technician-Grade-Dielectric-Grease-05113/206843029
Bernzomatic BZLTR300 Premium Flex Stem Utility Lighter; http://www.homedepot.com/p/Bernzomatic-BZLTR300-Premium-Flex-Stem-Utility-Lighter-346995/301636874
Hot Knife Solder Tip; https://www.amazon.com/Weller-HK11-Knife-Solder-Chuck/dp/B00HDSQ5TW?SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duckduckgo-osx-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B00HDSQ5TW
Craftsman stripper / crimper
Small black zip ties
91% Isopropyl Rubbing Alcohol
Needle nose pliers to open up shrink tubing to fit over connectors
IMG_9218.jpg.9ba75a2341f78e9a1a742da02dbb0cc5.jpgIMG_9223.jpg.8835ff6709003b7788b0bdec88cc91de.jpgIMG_9224.jpg.449a90b02b691cb301f191c4f2e94256.jpgIMG_9226.jpg.d8f36782fb9bb860224a8e999b687c84.jpgIMG_9228.jpg.285d2b79d0e2c62ddfdf25ce8182c31a.jpgIMG_9229.jpg.62966045b448f0090c961503203b77ff.jpgIMG_9230.jpg.19d8d1dfd6978d0808af7aa412263153.jpgIMG_9220.jpg.a1f18d7e512984875c7771db4c63f262.jpgIMG_9221.jpg.27ed25721ddaa074aa4e5b32c72347cc.jpgIMG_9222.jpg.09e0fd8052383e1737e433231b51ff0c.jpgIMG_9231.jpg.fdedbcbbe3c5ee87c4d4b6cd9e14b1f9.jpgIMG_9232.jpg.5517cf831d5aa8e5e57435ac7c19503d.jpgIMG_9233.jpg.0aac47eeacbe4f4575b6e36a68e10bb2.jpg
Edited by Bedunjgi
