Repair or replace stator?
The battery on my DRZ hasn't been charging and I traced it back to the AC generator. The voltage on one of the phases was 8VAC at idle and 25VAC at higher rpm, compared to the others that were 25VAC at idle and 75VAC at higher RPM.
Resistance checked out (.9 Ohms across each of the three coils).
Is it possible to repair this somehow, or do I need to buy a totally new stator?
We normally source a replacement stator assembly for a case like that,normally a new one with a warranty.Oem or Ricky Stators are the ones to get.Ricky also carries a unit from the same Suzuki oem supplier for less as well.
