2016 XR650L Project Build (Part #1)
1. IMS Smog Block Off Kit (I opted to keep the Snorkel & Oil Separator intact.)
2. XR's Only 14mm TDC / 30mm Side Inspection Plugs.
3. XR's Only Magnetic Drain Plugs.
4. UNI-Filter
5. Core Moto Stainless Steel Brake Lines.
58f59f026d3c0_CoreMotoFrontBanjo3.thumb.jpg.33a5a27ff225eae7db09b7557cbc099a.jpg58f59f0b67a8f_CoreMotoRearBanjo3.thumb.jpg.b21fca2b57e12f255e845d2c847b9d60.jpg58f59f0765441_CoreMotoRearBanjo2.jpg.80455ec892fd9b6da63a9203d866e674.jpg
6. Rejet / Main 160-Pilot 55
7. Free Flow 4Stroke Carb Hose Kit
Jets.thumb.jpg.5f201ef19894d45a758663f74e1ea3ed.jpgfreeflow.thumb.jpg.3c0b8e09415120c696cc4eb2410ea6d0.jpg
8. Bridgestone Rear TW302 (Death Wing)
9. XR's Only Full Exhaust w/Heatshield
58f5a31111f39_XRsOnlySlipOn1.jpg.6988ff287184d7aaf6c7543fe7d7ea98.jpg58f5a30d0d2c3_XRsOnlyHeatshield.jpg.052df3097013a4ba174fb8db5b031235.jpg58f5a316d325d_XRsOnlySlipOn2.thumb.jpg.6373656776d85a490c85f1eaaa738a65.jpg58f5a31cc4aa2_XRsOnlySlipon.jpg.9f5970bde770275d0f705e340ea5093e.jpg
10. WPS Rear Tail/Brake Light & Plate Bracket.
58f5a3f66e568_WPSRearLightPlateBracket.thumb.jpg.0bc20ded9a65238140f28afd3d829781.jpg58f5a3f920236_WPSRearTail-BrakeLight.thumb.jpg.6c96ef6595509cea7956eef07cae4344.jpg
11. XR's Only Chain Guide
12. XR's Only Front Reservoir Cover
58f5a56dc03f1_XRsOnlyFrontResevoirCover.thumb.jpg.4df238e99c6d32a92240bea0b259d1b2.jpg
13. MSR Shift Lever
14. XR's Only Pegs
XR's Only Oil Temp Gauge
Just waiting on a couple more parts to get it back up and thumping!  I will add the next mods soon, also pics after it's finished.
Edited by xr650l1
Your jets are going to be too big if you don't pull out the snorkel. The MSR shift levers are too stiff , if you hit the shifter hard enough on something it'll break off the shifter shaft. You're better off with the bendable Honda shift lever.
what size  jets do you suggest?
2 hours ago, baldy110 said:
And its way to clean, go get it dirty, its a dirtbike
Got bored waiting for parts over the winter, been cleaning while it's torn apart, it will be doing the nasty soon!
Pig is back together and ready to grunt!  (160 main and 55 pilot jets are spot on with snorkel)  Added a XR's Only Shark Fin rear rotor guard, Carbon Fiber Fork guards will be next and then all finished until next winter!58fe5bde76d6e_4-24-20171.jpg.8d6c053f731b4071b621d89edd701c04.jpg58fe5be4ee0e7_4-24-20174.thumb.jpg.abd1451774a2c2c1db98a6069bc7257c.jpg58fe5d3f75104_Fin1.thumb.jpg.39d23af3c66182c4bc42e8263d472f83.jpg
He is right, I broke my shift shat off at 28,000 miles.
