2018 rmz suspension?
Hey all sitting here day dreaming about the 18 rmz and excited for them to hit the states as the wife has approved the purchase of a new dirtbike for 2018. I'm a little curious of what motor mods have been done to increase power to keep up with the higher hp other brands and I've heard Showa suspension. Will this be the same fork as the Honda has? Just curious and interested If anyone out there has anymore info than me. Thanks.
Air box, throttle body and ecu have been changed and apparently bumped the horsepower up big time. Conventional spring forks too, will see if I can find the link from Japan
Throttle body left a lot to be desired in the past. A lot of room  for improvement. I gained decent numbers from the Injectioneering throttle body mods. Flameouts, hard start and the subpar bottom end were all addressed with the mod. Chopping the throttle is now butter smooth even for those of us with a heavy throttle hand. I can only fathom that there is little doubt, that is where a majority of the HP comes from. If the improved throttle body is anywhere near my modded throttle body I will be happy.
As for the forks... they are supposed to be making the move back to spring forks. Details on exactly which forks they will be are not confirmed.
Biggest news is the massive diet the RMZ has been on since last summer. I will definitely be paying close attention in the coming months to see if it is worth the upgrade.
Edited by BDubb106
Yeah I'm thinkin it's between the Suzuki or the Honda. Didn't like the Yamaha and haven't ridden a ktm. Never really been a fan of the green bikes and from the reviews the Honda is supposed to corner well. More motor while losing weight and still having great handling and cornering would be great.
Have you seriously heard it's dropped weight? How many lbs have you heard?
I agree 100% about the Injectioneering mod. One of the best mods ever done for the Suzuki
Yes... I do not have hard numbers but my buddies exact words were "it is not going to come close to the KTM or anything but it will be a big improvement over last year".
His info is usually pretty spot on. He said weight savings in swingarm, frame, airbox and engine.
I am sure it's gonna be a great bike,  but right now it's 18lbs heavier than the ktm. If you want spring forks, then add 3 lbs so it's now 21lbs it has to loose.
Then think the engine is the same castings, and it's heavy...so you've got to loose 21 lbs of the chassis. Does a frame even weigh that much?
3-4 hp is asking a lot with just a different throttle body.
That transworld article says it's coming with Showa forks oem stamp it it'll have the same 49mm showa forks Honda has now. The bike will loose 5-10lbs and gain 3-5hp. My bet is on that
On a different note the new engine platform is supposed to be the same correct? My current rmz crank decided to die taking the cylinder with it. The crank and cylinder are repairable and I was thinking of doing so and keeping spares on hand so when this happens again someday I'm not down in the best time of year for riding for two weeks with the new bike
I'm sure the internals will be the same, at least on the bottom end. Weight savings are supposed to come from the cases  from what I hear, so that is not 100% either. I will see what new info my buddy has for you. I do know that there are supposed to be changes to there head, so I cannot be certain whether that will affect the cylinder or not.
Cool. I also might just make crank replacement a yearly winter project to prevent further problems in the future
That's what I do... just makes things easier in the long run. Keep the spare though. If they do end up the same you will have one to throw in while the other is being rebuilt.
Edited by BDubb106
Yeah that sounds like a wise plan. Hey was it you that did ceramic bearings to gain some power? Not like I need it but maybe next time I might try it
The Honda will have e-start and in its second year. I was looking hard at the new Suzuki but will be going Red again. I started with Suzy and have a soft spot for them but not this year
Yep... they work as advertised. I would definitely recommend at least the wheel bearings.
Where can these be purchased? Are they more durable?
