xr250 tank shrouds
Hi
I have a 2001 xr250r and i'm wondering if the tank and shrouds on foreign xr models will fit on my bike and if so where I could buy them and would they be cheaper than the aloop kits.
Thanks
23 minutes ago, bikeguy64 said:
Hi
Thanks
From what I've heard the Aloop kit is actually 98-99 CR250 parts that are modified.  You may want to pursue that angle.
Ok thanks for the advice. I will look into that.
The Frame yes , but i don't know what Tank your bike has .
If your 2000 XR has a sheet metal Tank again yes
If you have a plastik tank you need to change the front mount and the seat
the newer models also have a support for the lower corner of the shrouds (Part 20 in the Parts diagram )
and the mount for Part 20 on the Frame is not existing on your 2000 Frame .
I have a 97 and a 04 XR250 and a 06 XR400 and mix and match the Tanks a few times
Edited by Schrauberklaus
16 minutes ago, Firestone said:
They are hard plastic. They crack and the front tabs break off. Not if but when.
Aloop addresses that issue on their website.  They claim its operator error.
I hate to call their bluff. But NO.
Two used ones I got were broke. Two new ones I bought lasted about 5 hare scrambles respectively. My brother's OEM seats not a hint of problems, also racing.
Don't get me wrong.. I am just glad they still support and sell them.
Edited by Firestone
And that is why I have never gone that route.  For the price they want it isn't worth it, IMO.  I spoke with a lot of people, including you, about possibly buying the Aloop setup before I just finally said no.  I am still planning on looking at modifying a 98-99 CR250 setup if I can ever find a tank cheap enough.
If you want to change over to shrouds badly enough to modify stock CR parts, then the Aloop is a good deal. A little aluminum repair work on the seat bases can greatly extend there life.
I think when you asked me about it it was in the context of was it worth it for the performance vs keeping it stock. But I would go Aloop if you are bent on making a change. Stock CR seats are going to be the main problem. Not even close to fitting. At least I had a 99' and it was not even close.
