wrf front wheel on a YZ?
Does anybody know if a wrw250f front wheel will work on a yz?  It does have a speedometer part which could be easily blocked and sealed.  I'm more concerned with the fork/brake spacing and axle diameter.
It probably will. I think the fronts are almost all identical from 1999-2013(?) across the yz, yzf, wrf lines. You'll want to look up the Yamaha part numbers for each bike and compare.
Look at this website
http://www.yamahapartshouse.com/oemparts/a/yam/5004753cf8700209bc797f55/front-wheel
Look at the part numbers for these components. If they are the same, it will be a perfect swap. More than likely, the wheel collar (spacers) will be different because of the odometer. You *should* be ok just using yz spacers.
Front Axle
Front Weel Collar Right
Front Wheel Collar Left
Front Wheel Bearing
  • Like 3
There are also many threads on this topic, but it helps to list the year of your bike to help narrow-down the search.
Good luck, and keep us updated with what you find. :thumbsup:
P.S. Excellent post, spud!
