WR 400F Supermoto from Germany (carbon tank?)
Hi,
I´m from Germany and rebuild a Yamaha WR 400F from 2000. I put the plastics and tank from a YZ 450F on it. Also rear frame and seat bench. A Akrapovic duplex exhaust with removable silencers.
Here some pics.
I need your help to find a carbon fiber tank or a carbon fiber tank cover. Looking also for other carbon parts.
Thanks for help and sorry for my simple english.
Edited by Rich_WR
  • Like 6
Nice bike, I love all the extra little details you put into it.  Very clean, with 6 thumbs up.
Thanks. I added some extra details but I'm still searching for the carbon fiber frame guards.
16 hours ago, Jens Eskildsen said:
Hey man, Im just here to say I relly appreciate the attention to detail 😃
Thanks 😉
6 hours ago, AngryDrone said:
What is your starter setup like? I also have a 2000 model and would love an e-start.
Kick start. You can install a auto decompression camshaft. It will make the start process a bit easier.
I have never seen an e-start on a 400 or 426.
Richard
Richard
I saw your battery and incorrectly assumed you had an e-start. Makes sense!
Beautiful bike, I believe I’m following your Instagram wr400conversion.
is that the 03-05 style plastics and subframe? I’m looking to also add a battery and wondered if that fits well or required much modification?
Thanks buddy, my IG account named yamaha.conversion
Yes, I used plastics, subframe, tank and seat from YZ 450F 2003-2005. At the moment I have some trouble with these "floating ground".
Richard
Richard
Yeah that’s the one.
I think I’m actually running the WR400 airbox still in mine so I don’t have a good spot the put the battery unless I build my own support. I’m about to re-address floating the ground, but I removed the ground from the stator years ago and had a reg/Rec installed previously. I’m in the middle of wiring lights up and figuring out where to mount everything. I have seen some people remove that little regulator like you have on the side of he frame but I can’t find any info on what needs done to the harness when it’s been removed.
Justin
ig, Justin.gregoire89
Justin
I installed headlight, turn signals, rear light with break light and a horn. Wiring to battery including a handlebar switch is no big deal. I think I will install a regulator rectifier to switch AC Power to DC to charge the battery.
Richard
On 4/20/2017 at 1:20 PM, Rich_WR said:
Hi,
Here some pics.
I found this while searching for a black tank for a 2004 yz450f don't know much more about it.
http://crmcompositi.com/product-category/yamaha/yz450f/fueltank-yz450f/
