LHRB fittings for custom line to rear caliper
Bike is a KTM Freeride. I bought a Rekluse LHRB lever/master cylinder amd would like to run a line directly to the rear caliper and remove the foot pedal.
Does anyone know what fitting would work for the Rekluse/ Hayes master cylinder to be able to use a braided motorcycle hydraulic line?
My other option is a mountain bike line (5.5 OD) which I can find a compression fitting for however I don't know where I can find an 8mm banjo bolt for that line to connect to the rear Formula brake.
Thanks for the help!
Hydraulic shops can custom make a line with fittings, check your local phone directories. Because of line length I'd recommend a braided line to reduce pressure flex which causes a soft feeling brake.
