2017 TE300 Rekluse Clutch
I cannot get my Rekluse to engage fully. My clutch handle is very loose to the touch. I have tried making adjustments to the slave cylinder. Should I try bleeding the clutch? Give me all your ideas, even if you think I've already tried it, I'd rather hear it it twice than not at all. Thanks!
It sounds like you may have some trapped air in the clutch system. I would try bleeding the sytem again, then adjust your freeplay....Good luck...
Thanks! Bleeding the clutch fixed the problem! Works awesome! I had to get a different screen for my exhaust pipe it was getting clogged up, that helped a bunch.
