1993 KLX 650 won't start in Neutral or with clutch pulled in
Help! I recently replaced the battery after this winter and went for a ride, got stuck in a rut, tipped the bike and broke the clutch lever and partially broke the cable
But before this, the bike wouldn't start in Neutral unless the clutch was pulled in and the choke was all the way out.
After the crash I was able push start the bike and limp it home.
Replaced the lever and cable and now it will not start at all. In nuetral with or without the clutch pulled in.
The only way to start it is to push start.
any ideas here?
Edited by MckayM
You should check that you have your new clutch lever and cable adjusted properly.  Sounds like your clutch might be dragging and not allowing the engine to turn over freely enough to start with either the electric or kick starter.
