Can someone tell me what these are.
I found these when i took off the stator cover. They look like dowel pins to me.20170423_172936.jpg
Dowels for lining up your case halves, cylinder, head or head cover1492996078806.thumb.jpeg.d3e2864a3cd2ff617a2874120ea1d9c0.jpeg
That's what i thought, but it has both dowel pins in there. The manual says it only has 2.
Head cover to head has 2, head to cylinder has 2, then your case halves should have 2. Plus your clutch cover and flywheel/mag cover has 2
Did you take anything else apart. They can fall out easy
I go back through it, thx.
There are a couple pins that go on the outside of the camshaft bearings to keep the bearings on the end of the camshaft and keep it centered.
