2017 300XC Lower footpeg option?
The cheap option to get them 6mm lower is fit the sx version pegs as I did which are lower as standard. They raised the height of the enduro bikes whilst the MX kept the lower pegs. Worked ok for me
Check the part numbers if the SX footpeg differs from XC / XC-W?
I found out that at least -17 Husky FC peg is few millimeters lower than FE peg and changed them, happy with the results!
Edited by Husabetunia
So after taking them apart, what I did was grind down about a few mm of material off the footpegs where they sit up against the frame, and that lowered the pegs about 1/4 inch to 1/3rd inch.  I just found they were angled up very high in stock form.  Doing this flattened them for no cost and worked great.
Should have taken pics, but I already put everything together.
I tried the SX pegs on my 17 300 XCW and they were not enough. Went with the expensive Fastway, and I really like them. I like how wide (fore-and-aft) the Fastway pegs are, makes it easier to stand.
The steel fast ways are around $150, not to bad. I've been running them for about a year. I like how it moves them down and back a little
