93 Cr250r won't shift past 1st gear
Hi, I have a 1993 Honda cr250r. Everything on the bike seems okay expect for the shifting. The bike can shift from neutral to first but, wont go any higher. I don't really know what it could be, maybe the shift drum or the forks. Any help would be greatly appreciated. Thanks!
Usually if it's the drum it is stuck in gear. First check make sure shifter isn't bent hitting mag cover . If not then take right side case cover off check shift mechanism could be something in there. If not then I'd say possible bent fork or I've seen pinion gears weld their self to shaft. I always say stuck in gear not shifting is always better than slipping in gear lol less $$$
