SSS adding oil?
I have my SSS forks where compression feels good but they bottom a little.  Haven't pulled these ones apart to look inside but I want to add 5-10ml of oil, can I add it in the bleed hole or do I have to slide putter tube down to add it?
add into bleed hole. compresss the forks { a little bit} after you remove the bleed screw .use a syringe with a needle and as you compress the needle plunder slowly let up on the compressed fork.  this creates a vacuum and allows the fluid to enter the tiny hole.
Edited by cj_wai
