Is there a way to increase throttle grip pull back
Might be a dumb question, but is there any way increase the throttle return. I like the real snappy pullback of the throttle on my ktm. My Honda crf used to have a good snappy pull back too. Ever since I got the kx its always seemed almost to easy to twist the throttle. Ive replaced the throttle tube and its  all clean.
Yes, there are two cables coming from the throttle housing,(near the actual throttle), the closest one is the one with the adjuster on it, just tighten it up, I had to do the same thing because it wasnt going all the way back and the throttle could just sit there at 10 grand if you let it without returning it back yourself, but I adjusted it and its all good now, real snappy
mine has one adjuster. And it only adjust the trottle. It doesn't adjust the pull back
What year is your bike?
hmmm mines a 13, wonder if kawi changed up there throttles
I have a 13 and a 16. They both have 2 throttle cables coming from the throttle tube.
Yeah his bike must have an aftermarket housing on it or something, very odd
I attached a picture. It has one adjustment right near the throttle. Best pic I have now. Bikes at my shop
go down the throttle cable, that one isnt the only one, im talking about on the actual cable
right near your bar pad
Yea I know about that one but it just adjusts the the trottle pull. I have it set so there is no play right when you twist the throttle
I set mine so when I let off the throttle it hits the throttle stop fast and hard, it returns really quick, mess with those cables
Wrong throttle on the bike that's like a 2 stroke throttle with the one cable ... chances are ya pop the tank off and you'll see the throttle body with a whole in the cover for the second cable ya need a new throttle tube and housing for the kx250f
Look closely there are two cables
