Decipher my shim stacks 2006 YZ250
After not riding for over 10 years I decided to get my 2006 YZ250 out of the shed and service it.
I want to thank everybody on this forum for giving me tips and advice on getting it set up and ready to ride again.
I opened the front forks to change oil, seals and clean it.
This is what I found and it does not match with anything close to a stock shim stack. I use to send out to be serviced.
BV
Nut, Cap, spring,
30.4
Gold Valve (35 out diameter, 28.42 inner diameter)
6 -30.15
17.11
5 - 26.15
22.11
30.1
2 - 28.1
2- 26.1
2 - 24.1
2- 22.1
2 - 20.1
2- 18.11
washer 20 1.6
MV
nut, washer (13 2.2), spacer (12 4.75)
10.2
11.11
12.1
14.11
16.11
18.11
20.1
12.1
3 - 20.1
Gold valve - bleed hole drilled (24 diameter)
4 - 20.1
18.11
16.1
14.1
11.1
17.2
2 -14.1
Spring
Cup
When I tighten the nut there is no movement from the MV washers above on the spring. The spacer seems to have been put there to close this gap.
In the past I have sent out to be serviced. I use to race MX (before grey hair and kids), I want to set back up for a beginner and go from there. I thought I would just put back to stock set up as my base going forward. It looks like I would need to buy numerous shims to do that. Before I do that I wanted some opinions on this set up and what I can expect from this configuration and what/why this was to accomplish. I know it is my bike, but I was lazy in the past to have done by somebody else without knowing what or why.
I would like to have set up for beginner, fat 220lbs MX rider and modify from there as I get more comfortable riding again.
Your thoughts on this set up, why the strange pattern to the shims when compared to stock, can I use this set up for now or if I should go back to stock set up and buy new shims.
Thanks for your advice.
If you have no float it will be stiff for sure
