fork oil
i have a 2000 cr125 and i was wondering how much fork oil goes into the forks? in CCs please
Drain old oil, collapse forks remove springs add 155 mm or 6&1/8 inches standard or 139mm or 5&1/2 inches max. the later will give you a better ride. I would mix 5wt. and 10 wt. in equal parts and then use a measuring cup for the oz. to keep a record for the next go around for the height you desire to use. I found it a pain in the shorts to hold a light plus try to measure down into the tubes and get the right height. Once you do 1 tube and find the height you want and know the oz's then the next tube is a no brainer!
