Tusk enduro kit 06 tail light
I'm looking at the tusk enduro kit for my 06 Wr450f. For those who have it, did you have to replace the rear fender with built in tail light?  The kit comes with a tail light/license plate mount. If not, does the stuff from tusk just bolt to the stock rear fender?
I have an 01 WR that didn't have a tail light on the fender. The Tusk kit will just bolt to your fender. Since you're has a tail light you could just take the tail light off of the tusk kit (it's secured by two bolts) and put it on your fender and then use the license plate mount from tusk by bolting it to your fender. You might even be able to wire up the tail light you have already. I'm not sure if that works, but it might only take hooking up the sensor to your brakes to make your tail light work as a brake light as well. The turn signals are mountable anywhere so you don't really need to worry about those. Hopefully that helps!
