Help!! Almost done rebuild Need help with cam chain
So I'm almost done a rebuild but I can't seem to get enough slack in my cam chain to go around my cam gear!!! Am I missing something cam chain tensioner is off! Need help asap!!!
The chain must have slipped down and over the small metal tab below the lower crank gear, it can easily happen.
Hopefully the metal tab didnt get bent out of shape, easiest thing to do is remove the cover so you can see that area and make sure everything looks right while getting the chain back on the lower gear.
I got it! Tried once more after I posted and it came up and over te gear! Thanks!
Got everything back together bike fires up and runs good but now my light flashes twice?!
It would do the usual flash on start up and than two flashes and it would continue to do that. I got it figured out tho.. there was a hose on throttle body that came off. Must of happened while I was fighting with it trying to connect the air box lol hit the track sat and broke it in everything's good! ?
