Pitbike won't run
I need some help with my pitbike .I have a Baja 70 that has spark fuel and air. It runs good if it starts sometimes it starts first kick and runs fine other times u sit there and kick for 20 minutes and it won't start  unless you pop start it. Idk why it seems to have good compression when you kick it and if u spray starting fluid in the cylinder it won't do anything it's really annoying cause if I ride it somewhere and it won't start and I don't have anything to pull it with so I'm kinda screwed .
I have an SSR 70 and have had the same issues couple times. All I do is buy a new pz19 carburetor off eBay for $17 and runs like new again.IMG_1549.JPG
Hey- I like your setup. I just bought my son an SSR 70C. I'd like to improve the suspension. What are those front forks? How long are they? Is that the stock 10" wheel in back? If not, did you replace the swing arm? Did you use a new rear shock? Or add extensions?
Thx, rico
