YZ250 steering steam bearing
Hey everyone,
been slow getting to my new to me 2014 YZ 250 but i finally got to wash it off last night and will start to work on getting it in mint condition for the season this weekend. i happend to notice as i was moving it around the garage that the steering was fetching up, and upon a couple twists of the handle bars i noticed a deffinate spot where the steering steam bearing is catching. this bike was bought as a hold over and rode a summer and a half or so with pretty much no maintenace according to the pervious owner. i am just wondering if this is common on these bikes? i have had a pile of bikes and never had the issues i see with this one (steering steam bearing, rear shock seal blown and no rebound). its all fixable stuff just wondering if anyone else is having these failures on a bike this new, as well as should i replace the bearings or just give it a good greasing. thanks!
Get in there and look at it first. Sounds like to me the bearings ate rusted and potted quite a bit. If so, then you will have to replace them. You can take a brand new bike an maintain it well, but if you pressure wash it around the steering stem then that water gets in there and causes havic.
  • Like 3
Chronic, premature rusting of the steering bearings (especially the upper) is real common on the aluminum-framed YZ 2-strokes.
There are a few threads on the issue. The best solutions seem to be;
1 - Replacing the top seal with a 4-stroke seal (YZF or Kawi) - they are thicker and do not deform.
2 - Replacing the top bearing with an All-Balls or late-model unit - these both appear to have a built-in seal.
Good luck, and keep us informed with what you do. 👍
  • Like 3
36 minutes ago, CaptainKnobby said:
...You can take a brand new bike an maintain it well, but if you pressure wash it around the steering stem then that water gets in there and causes havic.
This appears to be a common denominator - frequent power-washing. The stock upper seal does not fit tight to the frame, allowing water pass straight to the bearings.
thanks for the replys, i was just wondering hadnt had that issue on any other bikes, the bike looks very clean just needs to be freshend up i think (hope). i will start another therad with pics once i get going on it tomorrow!
  • Like 2
I'm wondering too if the upper bearing problem is compounded by the mount post if you have a stabilizer?  It seems to channel the water in there.
My solution has just been to keep them heavily greased.  As long as they are not pitted, a good cleaning and greasing should get them back into shape.  Chassis bearings are certainly subject to stresses, but they don't have to be as pristine as, for example, crank bearings.
I bought a 2 year old YZ that had less than 5 hours. Upper bearing was completely rusted. Luckily it is an easy fix for a bike that is otherwise pretty stone reliable.
  • Like 2
no stabilzer on this one, bone stock right down to the tires. i think with a little elbow grease i should have close to a brand new bike for about 1/2 the cost.
