Wheel bearing change?
I changed my wheel bearings with the pivot works upgrade kit which u done use the retaining clip. I am now doing wheel bearing again and I don't want to go with the upgraded kit this time but I don't know where I put the retaining clip. Do I have to use it? How important is that clip?
The retaining clip locks the sprocket-side rear bearing in place, wich means that after you insert the new sprocket-side bearing down to its place you install the retaining clip into the groove in the hub.
Edited by Earthmover
