2006 crf 450 trans oil getting in motor
i have a 2006 crf 450. the transmission oil is getting low and the engine oil will overfill.... right side crank seal are could it be something else?
Main bearing seal on primary gear side is toast. You can pull primary gear and replace it without splitting cases, chances are it's a sign the crank bearing is worn and allowing it to wiggle.
