Lean at Idle
I am running lean at idle and adjusting the mixture screw will not resolve it.
I get a hanging idle and 99% sure its lean. I did the side cover off vs on run and no effect.
Outside of the idle the bike runs strong especially on top.
What should I change to add a bit a fuel at idle range of 1800-1900 RPM's.
My Setup is below and I have a Full MRD and 3x3 and K&N.
160 main jet
200 main air jet
EMN needle
clip 3
45 pilot jet
remove pilot air jet
2 turns fuel screw
o-ring mod
R&D Racing Flex Jet Fuel Mixture Screw
Thanks so much for any help you can give, I am struggling.
I found the standard TT jetting to be really junky at low rpm's and at idle.
Try putting the #100 pilot air jet back in and drop the pilot jet to a 42 and also important the float level should be at 9mm.
bumtarder I just made he changes you recommended and raptor petcock mod.
Wow what a huge difference down low, runs so much stronger on the lower end.
Thanks a million for the help, I really appreciate it.
For those interested here is where I ended up.
Sea level,aftermarket pipe with open muffler and BMC air filter.
TT Store FCR39 Kit
160 main jet
200 main air jet
EMN needle
clip 3
42 pilot jet
100 pilot air jet
2 turns fuel screw
o-ring mod
Float level at 9mm
