How can you identify which showa forks you have?
Hello, I recently picked up a 2002 cr125r, and it needs new fork seals. The right fork leaks alot of oil and the left one just barely does. I know the forks are not stock and they are showa, because there is a sticker on them that says showa, but the model number is faded out. How can I tell which ones I have so I can get the right seals?
I can attach pictures if needed.
Thank you!
How many millimeters are the lower tubes?
Showa forks usually have some letters casted in the axle lugs, like KRN or similar, what do your's say?
Yes post some pics of
the top compression adjuster / cap,
external area where the seals are on the upper tubes
etc.
Edited by mlatour
