02 cbr600f4i fuel pump won't prime!!!
Bike sat all winter pull it out fired up left key on battery died, charged back up and the bike won't prime now!!! Cranks over fine. Don't know my issue the relays click check most of fuses I can see. Need help if I can get it!
Lift the tank up and see if you're getting power to the pump. If no, back down the wiring until you find where the power stops at. If you're getting power to the pump, chances are the pump is dead.
