Well guys i need help...
I bought a 2005 crf450r and the bike is now leaking oil out of the airbox quite a bit
I tried to drain the crank case tube but that did not help
Should i suspect its the crank seals?
If it was the crank seal how much do you think a shop would charge to fix it
Considering its about $75 hour here?
It is unlikely that crank seals have anything to do with it, if you are finding oil in the air box it is because you are likely running too much oil causing oil foaming due to the crank shipping it aroind or getting foaming due to running the incorrect oil or a contaminated oil.
How do you adjust the oil level in the bike?
