2014 kx450F waterpump/weep hole leak
Hey guys I have a good amount of coolant dripping out of my weep hole right underived the water pump. Drained the oil and don't see any signs of coolant. I did a little bit of research and it looks like the outer water pump seal is bad, this seems to be just an easy removal of the water pump cover to locate and fix. Do you guys think I should crack the case, dig a little deaper and replace all seals and bearings?
The bike only has about 20 hours on it. But i did have a BIG wreck  end of september last race of the season added some more broken bones to list. Didn't ride until last week and then today after a second ride I noticed it dripping in the garage.
Thanks!
I think you should just fix the leak on the water pump and call it good. There isn't any reason to change all the other bearings and seals at only 20 hours
