Fresh top end bike won't idle
I just did a top end on an rm 125, the bike would stay running before I did the swap, now I can't get the bike to idle properly. It starts first kick and will idle for a minute but won't stay running without some throttle, also struggles whenever you click into gear. I'm running 32:1, adjusting the idle and air screws didn't help much, my float was good and I cleaned all my jets. Not sure what to try, any advice is appreciated. Thanks.
Edited by Granger
if the airscrew does nothing then the idle is to high , if the idle screw does nothing the tip might be to worn out
if they both don't have any effect  ( both add more air ) then the pilot might be way to big
fresh engines are a more efficient air pump and require cleaner/leaner jetting
