How to fix rear brake?
I have a 2004 crf50 but the rear brazalete is weak as shit!! I have to press all the damn way down to stop my rear wheel. I adjusted the rear brake assembly tight in the rear but it's still weak. I tried loosening it but that was even worse so I tightened it back up. do I have to change something for it to work properly? Image1493950902.827697.jpg
Add some more swear words to the post, you'll get more responses for sure
Didn't know people were that sensitive lol
Take the rear wheel off the bike and see if you need new rear brake shoes, and, if you don't, move the actuator arm (part #3 below)  back a little on the splined shaft (part #8)
How do I know if I need new brake shoes?
Yeah, but how do good break shoes look like and how do bad brakes look like?
If you want to get technical, measure your brake lining thickness on the pad. The service limit is 2.0mm (0.08 in).
Ok thanks bro.
