Starting issues
Hello everyone,
recently I have come to notice that my drz will not start using the starter button. However I can jump it by using a pair of pliers onto the relay located on the ride side of the fairing. My question is, does the relay need to be replaced? Bike runs absolutely fine, battery is perfect, I've checked/cleaned the contacts/wiring to make sure everything is tight. Put the battery on a tender every so often. Also when I go to press the starter button the headlight dims out which is perfectly normal but I don't hear a click or nothing, just silence.
