Help with rear disc caliper bracket pls
I've been gathering parts to switch to rear disc brake and this rear caliper bracket has a locating pin. How did that originally interact with the swing arm it would have been matched to?
Picture please
I may be using a mismatch of parts-but the shops here can make anything work usually. Just curious what the original set up looked like
Well it looks like the same or same style caliper bracket was used on XRs 250, 400, and 650. Looking at parts diagrams there's nothing special between this bracket and the swing arm except for a U shaped steel piece that bolts to the inside of each side of the swing arm
