Kx125 piston size
Hi i have a 1997/2001 kx 125 basketcase and i bought a piston for a 2001 cuz i checked the vin before anytbing else and i was wondering if a 2001 kx 125 piston will work with the 1997 motor? Any help is appreciated
what size does the box say it is ?
what size is on top of piston ?
if it is bigger then say ~53.95mm  it is to big
i did a quick google search and came up with 54.5mm for 1997 piston
So the piston box says 53.97mm and idk what the old piston says because i havent pulled it apart yet
Have you checked your manual for the OEM bore of your cylinder and the recommended clearance tolerances relative to the piston and rings you've bought?
I dont have a manual cuz i bought the bike used and its a frankenbike
Based on KXRob's Google find, your piston should be right taking into consideration the rings.
Okay i found a repair manual for both years online and the only difference in piston size is like 0.002 mm so i think ill give it a go and hope it works. Thanks for the help
