2005 crf450 leaking oil
Well guys i need help...
I bought a 2005 crf450r and the bike is now leaking oil out of the airbox quite a bit
I tried to drain the crank case tube but that did not help
Should i suspect its the crank seals?
If it was the crank seal how much do you think a shop would charge to fix it
Considering its about $75 hour here?
