Idle problem 2008 ktm 250sxf PLEASE HELP!
I have a 2008 ktm 250sxf and I'm having a lot of problems with it. I missed yesterday's race because it wouldn't run right. It's idling really rough. Every few kicks it will back fire really loud when I get it to run it will idle rough and when I give it gas it will bog then when I release the gas it will rev high and is hard to come down. I will give it the smallest bit of throttle and it will stick at a really high idle and I have to rev it hard and quick a few times for it to come back down. When I put it in gear and try to ride it slowly it just tries to take off and it doesn't even feel like a high idle. I have to ride the front and rear breaks for it to not take off. I can let off the throttle and put it up to 6th gear and it still keeps going. I just had the entire top end replaced. Cylinder piston rings etc. I cleaned the carb several times cleaned all of the jets and still nothing. Replaced the throttle cable even disconnected it and still nothing. If I disconnect the throttle positioning sensor it runs a little better but is still pretty rough. I used a multimeter to test the tps and it seems fine other than when it's at "idle" it's at 1.14 on 20k I give it a little gas and it sticks at 1.17 until I rev it hard a few times. No idea what it could be. Needle and seat seem fine I'm stumped on it. Please help!
You have a massive air leak.
Probably the hot start is broken and pulling in air.
That, or the slideplate is in upside down (hold goes on the bottom)
You have to maintain the ENTIRE carb, not just 'clean the jet's if you want it to work.
http://www.dirtrider.com/features/protips/141_0707_keihin_fcr_carb_rebuild/
Edited by Krannie McKranface
