CR125 Won't Start After Rebuild
Update: I disconnected the carb, and The throttle cable only goes about halfway down.
I started the bike earlier, and it starts up with a super high rpm.
And I had to shut it off to keep it from blowing up.
So I'm wondering if the throttle cable needs to be replaced or if it's normal for it to only go halfway down the slide.
Here's some pics for reference...
I had the same thing happen on my RM 250, after being redone. Had the exact same problem..  As stupid as it sounds, check your throttle cable. I paid 100$ for some tech to replace mine( Damn i was pissed). It could be adjusted wrong, be pinched, or seized in a bad position.
Edited by peyton mcadams
Yeah it's probably the throttle cable.
I noticed when I twist the throttle, it doesn't fully return, I have to manually twist it back another 1/4 of a turn
From your pictures, it is the throttle cable.
From these pictures, i would say that it is certainly the throttle cable.
Definitely the throttle cable or the return spring on top of the carburetor slide. Slide should shut completely if installed correctly.
Yes, it was. I pulled the carb off, took the cable out, found a piece of metal from another project in the jet hole, that was keeping the slide from closing properly, took that out and reinstalled everything.
Now she runs great.
Lol out of all the things that could have been wrong, like a backwards piston, wiring issue. or something terrible.
It was a little tiny metal cylinder things that was in the carb...
Anyway thanks everyone for the help.
