02 YZ250 Wont start
Hi every 1 I'm new hear
I have an 02 yz250 ive just done the topend and installed new crank bearings and seals Now I cant get it to run Its got fire ive cleaned carb It will run for a half a sec then it dies Ive tried pull sarting it no luck The crank case had a lot of gas in it I cleaned it all out still no go Reeds are good its got me stumped  Thanks for any help Anthony
Check to make sure your crank keyway stock is in place,otherwise your timing will b way off.just a thought.
Try a new plug and kick her hard with wide open throttle. Especially if you crankcase is filled with gas before and you just leaned it over to drain out pipe spigot. Still lots of fuel in there that needs to escape. Hold wide open until sputtering stops, then just frap a little to keep running. If you have an open area, let it warm up a little then spank it hard.
key and timing is good  New plug + Did  a leak test no air leaks
I removed reed cage and swab all gas from crank case still no go
7 hours ago, Gary YZDOC said:
Are you getting spark? Nice arc not just a little. Make sure plug cap is screwed all the way on lead.
Getting blue spark I tried dif plug and coil still no go
what does the gap between rotor and pickup suppose to be it look to  be to far to me ill cheak it and post it in a few
its closer than it looked .018 I'm going to pull carb
Will any of them electrical parts on the carb keep it from running
Nope
Found the problem the cdi was bad tried 1 off anther bike fired on first kick
Thanks for all the help Anthony
