Battery replacement
There are so many aftermarket battery options out there, I am overwhelmed with the choices. I definitely want a lithium, but I would like your input on what you have, how well it works, and so on. I have a smart charger from other hobbies that I can and will use to charge the lithium. Also list a price with what you have.
I recently installed an EarthX EXT12A Battery and the Terminal Adapter kit in my '09 WR450F that I regularly drive on the street. They say lithium batteries don't like the cold but when the temperatures were hovering around 0C (32F) it had no trouble starting.
I went with EarthX because it was the only one that had internal electronics to automatically equalizes the cells which allows you to use a normal battery charger. The battery doesn't come with the terminal kit but I think it needs it to make the installation simpler.
http://earthxbatteries.com/shop/ETX12A
See also:
https://www.thumpertalk.com/forums/topic/1208425-wr450f-lithium-ion-battery-installed/
http://www.thumpertalk.com/topic/1119023-earthx-lithium-battery-in-2012-wr450f/
Edited by msowsun
It got drained below the safe voltage level and went into safety disconnect mode. Been siting out in the Minnesota cold for 4 months so what do you expect I guess.. I was not able to get it back out by doing their steps the recover. They sent me a new battery but other than that the battery works great, cranks hard and fast and saves a ton of weight!
