My brakes seem like there fading out
Does this mean new fluid my pads still have life, my rear tire doesn't lock unless
I slam on it, and not much braking power up front
Change out your fluids bleed out everything.
Flush fluid then bleed brakes at both ends.  Check both rotors for any distortion (grooves, warping, etc.).  Dress them with sandpaper.  Buy new brake pads.  The Neutron pad rockymountain sells are only $9 and they work fine.
If this does not make your brakes as good as new, then you have an issue with a master cylinder or caliper, but my guess is that bleeding the brakes is all you need.
