Fitting neutral light to DRZ 400 E
Hi guys. I recently bought a used 2002 Suzuki DRZ 400.
Paperwork says it's an S, but I think it actually an E. My dashboard consists of nothing more than a third party analogue speedo.
I have been road riding for almost 15 years, and really want a neutral light on my DRZ. I have a third party neutral light which seems perfect for the job.
Down near the gear selector is a little plate held on by 2 bolts. Behind the plate is a gaping hole, where, I am led to believe, should be some gubbins which talks to the neutral light switch thus tells the bike it's in neutral and lights up the dash light.
I have the neutral light switch, and the light. I believe there should be something like this behind the plate:
http://www.ebay.co.uk/itm/260375758313?ssPageName=STRK%3AMEBIDX%3AIT&fromMakeTrack=true
Can anyone give me some advice on how to rig up a dashboard neutral light on this engine? Because behind the plate, there is no working parts, I am certain that just putting the switch on and wiring it up, it won't work.
I can post up some pics if you need. Somone please help! I know I don't actually NEED the light, but I want it and have most of the parts, I just don't know how I can wire it all together to get the light working.
Thanks guys (this is my first post =))
The shift drum used in the S/SM is different than the E shift drum.  To get a neutral light you will need to replace the shift drum.  A lot easier to learn to live with the lack of a neutral light than to split the cases and replace the shift drum.  Your foot will learn to find neutral.
Well the are several reasons but simplest to understand is the shift drum assembles into the case halves before they go together.  It does no slide out either side.  I have not had a neutral light for 17 years.  It will take you less then a week to get used to finding neutral with your foot and verifying you are in neutral using the clutch.
I have the same thing on my stroker motor , shouldn't have had the E drum anywhere near where I was assembling the motor so I ended up with the big hole in it as well . I was always going to make a plug to go in the drum with the holes for the plungers in it to get the light back . I ride a pile of bikes and it's rather habit to look at the light it gets annoying when it not on one but so far I lived with it . Someday I'll make that plug , just need a good way to hold it in place without hammering a press fit piece in.
Behind the plate should be two small pins and i think a spring, if there are not even holes for the pins to go into than yeah, you would have to replace the drum. I guess if you were really adventurous you could drill into the shift drum to add the holes....
